Re: Mariner or Yamaha????
The engine plate reads: YAMAHA 20A with the serial No.653 L 300386.<br />----------<br />I checked on this (Swedish) site and it is a serial no for a Yamaha:<br />
http://www.marinshopen.se <br />(and button Modellguide in upper right corner, then link Yamaha on next page)<br /><br />653 1972-1978 P-400/20A (20HK) <br /><br />Does this No. make it a 1977 Mariner?<br />-------<br />Does not seems so...<br /><br />Stamped in the bottom corner of the plate is the letter U. I'm told this makes it a 1978 yamaha?<br />----------<br />That is correct.<br />Se above URL in the beginning of that page.<br />1978 - U<br /><br />A local repair shop said it was a japanese built (Yamaha) Mariner so I bought the Clymer Mariner Repair Manual 1976-89 but none of the photos/diagrams or specs seem to match my engine.<br />--------<br />Buy a Clymer or Seloc Yamaha repair manual that covers 1978 and you probably will get the correct manual.<br /><br />The book also says no more than 50:1 oil ratio for all Mariners but info on my engine says 100:1.<br />------<br />50:1 is the universal mixture gas
il that is used in almost all 2-stroke outboards, but if otherwise written in instruction book or elsewhere You could try that. I would use 50:1 to be on the safe side in all cases, 100:1 mixture will not give you much margins regarding lubrication, rust prevention etc that the oil is there for.<br /><br />It says MARINER on the engine cover but nowhere else. Now they think it could be a Yamaha with a mariner cover fitted!Any ideas? <br />-------<br />Mercury and Yamaha is, and has been, using same powerheads in many engines. I do not know for how long. Mercury and Mariner are, at least in later years, same engines. So probably You have a Mariner cover on a Yamaha powerhead and rigg. That would be my best guess (but I may be wrong).<br /><br />Good luck.
