Mariner peeing out the wrong hole?
Micahhaase
I have a 1995 Mariner 90 hp 2 stroke.. and last time at the lake it seemed to be peeing less as the day went on and after shutting off for a while it would pee strong then taper off again.. So i Just changed the impeller and fired it up on the muffs and i see its shooting a strong stream out of the bottom by the prop I have attached pictures Is this normal??? please let me know I would like to take it to the lake tomorrow...The high temp horn never went off so Im not sure whats going on.
latin monkey
Re: Mariner peeing out the wrong hole?
are you sure you got the water tube back in right?
Faztbullet
That motors a long shaft so check copper water tube for pin hole or broken joint....
Micahhaase
Welli blew out the pee hole and now it is nice and strong should I still be worried?
latin monkey
just keep an eye on it, they do tend to get a little crud in there
