Mark 28 throttle plate to spark advance synchronization.
steely51
I could get a book from Oldmercs for 75.00 for one old mercury , however if anyone could enlighten me a little I might get this otherwise good old engine functioning properly. On the troll Run Start lever , when in neutral position , fully to the start direction , the throttle plate does not open . if you put it in forward or reverse , then the throttle plate will open.
does the start troll lever only affect the spark advance , or should not the throttle plate open a little also ? It looks to me like the only adjustment for the primary pick up would be on the cam under the mag plate . Thanks .
