So far I have cleaned and reassembled the carburetors, gone through the complete ignition system and all wiring, replaced impeller, the timing is correct, I have not split the case or had the Pistons out. Compression is good and cylinder walls show no signs of scoring, and I found no signs of corrosion anywhere inside engine. I have done this all refrencing a factory service manual
