204 Escape
Ensign
- Joined
- Nov 17, 2007
- 909
Am considering using it, to "clean out" a car engine. DOes it work as advertised ?
Pros/Cons??
Thanx
Pros/Cons??
Thanx
O.K. makes sense. The car is a 1995, 3.1 V-6 Chevrolet, in a Monte Carlo. The car wasn't (in my opinion), well maintained. It is my sons car. I was just thinking of cleaning it up some. It runs fine, but there is no record of maintenance/history for us to go by.
replacing one litre of ATF for one of oil { only one on a complete oil change} will probably help the engine alot as the lanolin in ATF will soften the seals and clean the rest....its a gentle clean if worried put half litre in...we used to do it thru the carb before CATS came along..did they smoke...did it outside of coarse ,very old tech
Put it in, it will not hurt your engine. That stuff has been around forever. Also suck a can of Seafoam in through brake vacuum line, let it sit for about 1/2 hour then fire it up. Don't think you've done anything wrong as the engine will smoke like crazy for a few minutes and then go away. Maybe drive it down a street or road without much traffic.
