marvel schebler carb?
big rigg
ok I got the old elgin out and fired it off,it started and sounded good but only ran until the gas in the carb was used,pumped it up and restarted ok. the carb is marked marvel schebler m15,it is on a 1963 elgin 7 1/2. i have a open line on top of carb that goes to :confused: ?"help"? also does anyone know where the fuel pump is? i'd love to get this in the water soon,thanks,jeff
CATransplant
Re: marvel schebler carb?
There were two manufacturers of Elgin 7.5 hp outboards in 1963. One was McCullough. The other was West Bend. Look for the model number. Once you can give us that, we might be able to help.
big rigg
the engine model is 574.60090,a McCullough i think. sorry i didn't think the engine model mattered long as we knew what # carb. we were talking about.i'm used to working on old hotrods not boats.
steelespike
My manual indicates A Shebler model SUM carb. Fuel pump is in the bottom of the carb. The square cover is refered to as the pump body.Don't attempt any
repair without a manual.Power head removal is required to remove the carb.
The Shebler looks very complicated and if history hold true it probably is.
I think I would try to find a Tillitson carb it sure looks simpler.
You might ask at "ask the scott guy". He may have more info.
big rigg
thanks steelespike.....i'm still looking for info on the open vertical fitting right behind the choke plate,i can tell something was recently hooked up there but cannot find anything,it looks like a hose went in the top,and directly below that is another going straight down into the bottom end somewhere.
