Restoration man
- Joined
- Jun 14, 2012
- 73
Hi I’ve got 1976 boat that’s got osmosis blisters I know this can be a very Controversial , subject so don’t want to get into wether I should be doing this or not , I ground out the blisters a year ago and now have no choice but to finish it off and re glass what I’ve taken out , I know this is not a cure etc etc , and no I don’t plan removing all the gelcote , now we have got this out of the way into the job in hand.
I plan on doing this with epoxy and biax toped
Off with international watertight , and I’ve regularly washed the blisters out with hot water over the past year , when grinding out some of the blisters we have a very resin staved layup in places , I can’t keep grinding as I will have no hull left
I’ve used west system epoxy on other jobs on the boat and find this product to be very thick , ive seen the low viscosity Mas epoxy and it seems much thinner and will hopefully soak into the dry fiberglass better ???
And Apparently you don’t get amine blush just wondering what the forum think? Would Mas be better bet than west ? I’ve spent year deciding what to do and I won’t be swayed by using epoxy but hope one of you might have an option on this
