intrepidvoyager
- Joined
- Mar 24, 2009
- 216
MASSIVE HONDO TWIN 90 PROBLEMS 2008 EFI
All started in June with water in port engine starter due to leaking verticle shaft seal.
seal was replaced plus new starter ..... same thing happened 200 hrs later.
these engines are run 4 hours a day at WOT = 120 plus hrs a month.
Port engine blew plug 50 hrs ago .... was helicoiled.
Starboard engine has now started to get water in the starter .
Port engine is now leaking oil from the top of the engine.
I am not where the engines are so this is a long distance diagnosis.
Suspect that the crank bearings on both engines are toast ...
Any ideas ? local Honda guys are not cooperative !!!!
Thanks !
Thanks !
