Re: Master Auto Mechanic seeks Marine Mech.
Well, you came to the right place, ANT. Welcome to iboats. Grab a beverage, Pull-up a chair, and join-in. There are a few really excellent Jonnyrude wrenches in residence here (not me tho).<br />If the compression is in spec, re-ringing is the least of these.<br /><br />Any motor that has sat for longer than a year, and all these preventive steps must be taken;<br /><br />Absolutely, impeller replacement (every 2 years whether it's bad or not).<br /><br />While you have the lower unit off, drain the lower unit. Follow the general instructions found at this link---
Lower Unit Inspection <br />The carbs will need going-thru for sure.<br />You will want to rebuild the fuel pump, as they don't handle today's fuels very well.<br /><br />Every skipper worthy of being on the water, has those concerns on his/her mind allways. Weather,other boaters, underwater hazards, and of course, the equipment under him.<br />Even if you took every precaution,(which you are well-advised to do), stuff happens out there all the time. Spend as much mooney on emergency equipment as you can possably spend.<br />VHF radio,EPIRB, Signal flares, Dual batteries, spare prop, spare plugs, a dash full of gauges, a Towboat US card, a stout bildge pump, a good set of waterproofed tools all come-in handy,when they come in handy.<br />I still have that bug in the back of my brain every time I leave the dock myself.<br />Just as in auto tweeklin, the shop manual is a must-have also.<br />I live in L.A. -- that's Lehigh Acres, Florida, so I'm glad we can at least discuss boats here .<br />Again, welcome to the best site for us skippers ever setup.
