Woodbinekeith
- Joined
- Sep 1, 2009
- 86
Is a master cut off switch a good (necessary) thing to have. If so, where is the best place to locate it. I'm guessing that it would wire into the primary +ve wire somewhere close to the battery. All my electrics go through individual circuit breakers so perhaps a master switch might be overkill and just another connection that can foul up.
With a switch, it should be ok to leave the motor battery cables attached when not in use as well as the primary cables for the electrics - or will their somehow still be leakage that will discharge the battery?
