Materials to use for new floor in boat
Todd Peterson
I need to replace some plywood in my 1984 Beretta. The floor is soft an some stringers are rotten. What type of plywood do I need for the floor and what wood do I use for the beams?
tashasdaddy
Re: Materials to use for new floor in boat
i use exterior plywood for all, seal all edges, prior to install.
Todd Peterson
Thanks, Exterior grade plywood would be pressure treated. How many layers of fiberglass mesh and rosin do I need to use when I replace my beam under my motor mount?
bhammer
Ensign
Try to determine how many layers are there. You may be able to tell when you start cutting. Also, head on over to the restoration forum as you'll be able to read lost of the same repairs and ask lots of questions. http://forums.iboats.com/forumdisplay.php?f=22
Todd Peterson
Thanks, I am heading over there to take a look.
ezmobee
The plywood TD is referring to is not pressure treated. PT is too wet and would need to be dried out for a considerable about of time for the dampness to not have a negative effect on the glassing.
Todd Peterson
I have built houses and exterior grade plywood to me would be siding that needs priming and painting. Where do I go to get exterior grade plywood for boat stringes, beams and flooring?
I can build you a house, but not a boat....help
oops!
standard exterior grade ply.....
avalable any where.....good one side....not chip board......
as bhammer suggested head on down to the restoration forum....read the compleated projects forum.......super insights there
Todd Peterson
Great thanks.
It is hard to take advise from an 'oops', but you are right.
I re-floored my 1983 starcraft, with good one sided 3/4" plywood. However I coated both sides and ends with multiple layers of primer (5/6 coats) to really seal the wood, then painted (yes painted) the same with 5 to 6 coats, of outside paint, then re-carpeted. This was done 5 yrs ago and I have not had any problems!!!!!!
mainexile
In some places, you may see it described as marine plywood.;)
bhammer
Ensign
Great thanks.
Trust me, you want to talk to him. Might even pay off to head up North of the border and bring em a six pack....
As Tacklewasher said, just don't let oops talk you into extending your hull. :D
Todd Peterson
I used 3/4 inch ext grade plywood and west system epoxy. It is rock solid. I used plywood for the stringers next to the engine to for the bilge area and green treated 2x6 for the motor mount. All wood was treated with epoxy before it went into the boat and then 3-5 layers of fiberglass depending on the location. My 12-year-old son helped me until he got tired of cutting sections of mesh for me. I used about 3 yards of mesh for this project. I still have some stringers and kickers to put in.
The stringers are about 4 inches high and I will double them up. I found 2 gal of polygard foam for $89.00 that will expand up to 8 cubic feet. I will foam and then use pt 1/2 plywood for the floor and I will epoxy the floor, new carpet and seats.
It was easier than I thought, but lots of thought.
Andy in NY
Todd, I would not use PT ply for the deck. As it dries, it will shrink. Plus, the resin will not take too well to wet wood. I would use the same exterior grade ply for the deck, coating the edges with resin then glassing both sides.
Todd Peterson
Andy, thanks for the input. I took out the pt plywood floor when I fixed the stringers and motor mount. The floor was pt plywood. The wood floor was in such good condition, I entertained the idea putting the same plywood boards back into the boat.
Currently, It has been cold in Northern, MN. I neet to get my boat fixed to get in the water in MN
