Re: Max knots from a 35hp?
Boat load/design and prop pitch will be factors. If you don't have enough pitch for a light load, you'll max out the recommended RPM's before you get to the max speed your boat/motor/load could achieve.. Too much pitch and you'll not get to max RPM's or max hp.. If it's a light load with correct prop, 40+ should be a given..
