Max load of trailer, engine weight
Frankhanhart
Hi,<br />have a choice between trailer for 800 kg. load and for 650 kg load (diff. abt $1000). Boat is 545 kg, engine (40hp Evinrude 1992, be40elenj) not known. Suppose engine to be around 80 kg total weight will be around 625 kg. Too close for comfort for the 600 trailer I guess. Anybody know the weight of that engine ? Couldn't find it in my Clymer. Suggestions ?
Re: Max load of trailer, engine weight
Reguardless of the engine wieght,<br />The smaller trailer is Too Close to the limit, Anyway........<br /><br />No Limit left for Your Gear........
jlinder
You estimate 625 kg. Trailer is 650 kg. Leaves 25 kg to play with.<br /><br />Fuel - 10 gal is about 25 kg.<br />gear (life jackets, flares, cooler, etc) - how about an estimate of an additional 50 kg.<br /><br />Puts you at 700 kg already. Around the max I would want for the 800 kg rating and still have some headroom.<br /><br />And ever get water in the boat? What does that weigh?
Frankhanhart
You guys convinced me...how could I forget the gas and all the little stuff that you have to walk 2 times for before its in the boat !!! Will go for the bigger one. Thanks for the input <br />Frank :rolleyes:
beniam
To Frankhahart;<br />Goeiedag<br /> Batavier Pittsburg Pa
jlinder
batavier,<br /><br />Where is Pittsburgh? I grew up there
jlinder
Just read my post and found a dumb typo. Meant Where IN Pittsubrgh.
Mark42
Hi Frank,<br /><br />The motor weighs in at 84 kg (185 lbs) with electric start & manual tilt/trim. A little bit more w/power tilt/trim. <br /><br />Hope that helps.<br /><br />Mark <br /><br />Ps....<br /><br />
Jack, you are a riot. :D
