Max RPM 3500
onebadc10
I just took my 1988 mercury 135 to the repair shop because it would not idle.The shop installed a new stator.
It idles good now but rpms wont go past 3500 when pushing the boat.In nuutral it revs fine.Any Ideas
Thanks
tony
M
Maxz695
Guest
Re: Max RPM 3500
prop slipping? did someone say MAX? (RPM) Just kidding but prop comes to mind not a pro her may need rebush. No that can,t be it you have full rev if the prop was slipping you would have more than 3500 RPM Check to see you carburetor butterfly is opening all the way
Faztbullet
Re: Max RPM 3500
Take the wires off the rectifier and retest, if it runs fine the rectifier is bad and likely cause of stator failure.
onebadc10
Re: Max RPM 3500
voltage does go to 16volts at wide open throttle.Batteries are new.When you say unhook the rectifier and test do you mean to run the boat with it unhooked and see if rpms are regained?
onebadc10
Re: Max RPM 3500
Had time to do a little checking.Has two coils not firing.changed them with two other cylinders and the started working.So I guess the boxes are good.
What would cause the two coils to go out at the same time and the are are on different sides controlled by different boxes.They are sierra coils and with only about 10 hours on them.I replaced all 6 last month just to have new ones on the engine.
M
Maxz695
Guest
Re: Max RPM 3500
sent a link for 3 used coils on eBay in your inbox I think the from a 40 HP 1997. Bid at .99 and 9.50 shipping I think
Faztbullet
Re: Max RPM 3500
Send them back as they have a limited lifetime warranty, check the grounds to coils and ignition plate...
