Re: Max Rpm
I have not done a compression check but I will get one done this week and post the results, I did put the 15 pitch prop on and ran the boat and got 4300 rpm, But I was changing plug wires and noticed the #1 plug wire was loose coming out of the coil, way loose! I threaded it back in but have not ran the boat yet, I don?t know if what I did is even something I should have done or If I messed it up more, but the #1 plug was way clean and oil washed compared to the others. My new jets will be in on 5-26-09 and I will be out the following weekend to try her out, I am way concerned about the plug wire I hope I did not brake the core!
