I have a 1998 130 Johnson. I am toying with the idea of performing a ?Maximum Spark Advance? procedure. I bought the engine new and have never messed with it. I recently did a lot of carburetor work (remove and replace). My Clymer?s manual says to run the motor at 4500-5000 rpm without the prop. I do not like the sound of that.
If I do remove the prop and advance the throttle what should I expect? With the prop on I know what the rpm will be at full throttle, but what will the rpm be if I advance the throttle to full without a prop?
The boat is in the water at a dock.
