Maxxie's Drain Plug Pics
wickware
Is the drain plug showing in Maxxie Pics? OR! Is just his description as to where it is? I c/n reply to the post. Is it showing just above the skeg??
Take Care! JOW
foodfisher
Re: Maxxie's Drain Plug Pics
Nope, that's not the drainplug. Mess with that screw and you'll become intimate with the gearbox inner workings. The drain plug is still lower.
wickware
I am saying lower above the center of the skag. JOW
jerryjerry05
One more time.J
MAXXIE
Look at the other pic.'s. The drain plug is the "Hex" screw just in front of the skeg. I had a very hard time finding it due to paint, it is smaller than the other screw's on the motor. I'm told not to touch that one, I guess that one holds a setting in the gear box. I'll "PM" you the other pic. of the drain plug. Here's the pic. of the drain plug, Pic. was taken from under the lower unit, the right side of pic is the front of the "torpedo".I'm going to post a few test pic.'s somewhere else to figure why there coming out so big.
