Maybe something electrical?
JCSkeeter313
I have 1989 Mariner Pro-V 175 V-6<br />When i start my motor i get the usual pre-beeps, but then it will start beeping at me constantly. the guy i bought it from said i need a new voltage regulator. i was out on the lake and my battery went dead. so i am wondering if i just need a new battery or if anyone has heard of a problem with this.<br />thanks a lot for any info
wilde1j
Re: Maybe something electrical?
Pretty easy to check. If the motor is running, the voltage across the battery terminals at idle should be > 13.5 VDC. If not, either the regulator/rectifier is bad, or the AC to it is too low or non-existent. Suggest using a shop manual or take to a qualified tech. Doesn't sound too hard to pin down. Another thing to look for is high resistance terminations at the battery back to the voltage regulator.
JCSkeeter313
to tell you the truth i actually dont know where the voltage regulator is located. could someone tell me where it is. thanks
