AzFisherman84
- Joined
- Jun 23, 2012
- 12
My 1977 165 running hot after changing impeller. Storyline, I recently had to replace the upper unit seal because I founded oil in the u-joint bellow. So I figured I would replaced the bellows and impeller why I had the drive apart. I install everything as describe in the service manual, I the only thing I did differently was install exhaust tube instead to a bellow. Now I'm running hot, so my question is could the exhaust tube be the problem or could it be that impeller is not circulating water correctly?
