MC-1 and Mercruiser 120. Need Bolt Sizes for transom
dezmond
Good Morning everyone,
Hoping you might be able to help me out. I want to drill my holes through my transom today as well as steering relief holes. I am not sure what size to drill for either... Could someone help me out?
Thanks all :)
Dezi
Bt Doctur
Just measure the studs in the housing ,almost sure there 7/16 ths
dezmond
Thanks. That’s what size I got. The transom template holes are 1/2”. I figured I would drill oversize, fill with PB, re drill to 1/2” and use 5200 when I install the bolts. Does this sound right?
Nope,..... No 5200,..... If the transom ever had to come off,............ it Won't,.......
I drill the holes 1/2", 'n use a new fresh Merc transom gasket,.....
dezmond
Perfect thanks :). Any idea what the hole size is for the steering relief cut outs?
Ayuh,..... I just did one last summer, but don't remember which hole-saw I used,......
1, 1/2" maybe,..??
dezmond
FisherDan Thanks for that. I checked and my old gasket measured 1.250. I will get a new one for sure when I get closer to putting the gimbal and transom plate back on. I also measured my transom thickness and as of now I am at 1.870” thick. I believe I need to be at least 2” for Mercruiser correct?
