998cc
- Joined
- Mar 30, 2013
- 159
I am really confounded by this issue. The first time this happened, I assumed there was an issue with the bellows install. I took it all apart again, cleaned all the parts, glued, etc., etc., and reassembled. The second time, there is no question the bellows was on right.
Drive: 1972 MC-1 Serial #3392031 Drive and bellows have no locating groove.
Engine: GM 250 L6
Conditions: The boat is blocked up so the drive is level. When installing the outdrive, I line the driveshaft up with the gimbal bearing and slide the shaft through. It stops just before the spigot of the drive housing enters the bell housing. I tap a remote starter switch to line up the splines in the engine coupler. It just engages the coupler, slides in a little farther and stops. The drive will not move any farther into the bell housing without using force; something is hooking onto the bellows and sliding it off while the drive is being further inserted. The only thing in there are the U-joints, but being lined up with the coupler, is it possible the U-joint is dragging the bellows off of the bell housing??
Any ideas??
Engine: GM 250 L6
Any ideas??
