MC-1 Trim not working - one cylinder stuck
Rake722
Hi all,
Getting closer to the water ! Wednesday is a good tide and I only have 1 showstopper.
I took the cylinders off the mounts today to bleed and noticed that only 1 was working and doing the work for the other.
I undid the pipes from the cylinder and confirmed flow on activating the trim.
Bashed it a few times with a lump of wood but the piston seems jammed.
Having said that - the one that does work trims the leg but only very slowly so its not jammed solid.
Any ideas what could be the cause or is it a strip down ?Thanks.
ron.
