mckee craft removing old glue left from carpet
Benny1963
i have a mckeecraft im restoring someone put carpet in it it was removed
i have gotten most of the old stuff off . but what is left.
is not comeing up .i have tryed a couple of things .
the boat has molded anti skid and im not going to put carpet in it.
any ideas on how to get it up.
would help
thanks b 1963.
buckstop108
Re: mckee craft removing old glue left from carpet
Mineral spirits and a scrub brush with a lot of elbow grease worked for me. They most likely used contact cement that is waterproof. You could check the label on a can to see what they suggest to use. I just finished restoring my boat with new decks and carpets, I cleaned all the hatch covers down to bear metal. The mineral spirits worked but I would wait for a breezy day. It will be a dirty job.
tashasdaddy
wire wheel and a drill of grinder, dust mask, safety goggles.
Benny1963
the drill with the wire brush wont harm my gel coat
thanks b1963
tashasdaddy
yes, it will.
wire2
You may need to let solvent soak the glue for a while. Place a single layer of cloth on the glue, wet it with solvent, place a plastic sheet over it to slow evaporation.
If mineral spirits doesn't soften it, try something stronger, like acetone or xylene.
buckstop108
If you go with something stronger I suggest that you try it on a small out of the way spot. In the past I had some discoloration with acetone. That is why I suggested the mineral spirits, it will take longer and more work but a little safer.
