Challenger84
- Joined
- May 9, 2010
- 341
MCM 5.0L EFI 305 Will not Start.. Fuel Starvation? Cool Fuel Gen II? (FIXED ISSUE!!!) Fuel Pump replacement
Hello guys and gals,
I'm having a little issue with my motor.
engine
Mercruiser MCM 5.0L efi (305) model year 2000.. engine serial # 0L606892
Hull:
Regal 2100 LSR
Back story:
Took boat out tubing/wakeboarding. I go to pick some people up at the docks and boat starts to bogg down a little bit. I give it a little throttle and the engine revs up and stays running.
Get to the docks and load up passengers and shut the motor off.
As i get everyone aboard i go and start the engine and starts up.
As i idle away from the docks the motor sputters and dies and will NOT restart..
Take the boat home and first thing i check is fuel..
I go through the check list that i've found searching the site..
Fuel/water seperator--replaced --No water in tank but there is a bit of black crude.. (i have a plastic tank under the floor)
filled up the seperator filter with fresh gas and tighten it back up..
As i turn the key to the ON position i can hear the fuel pump whinning..everytime.
I go to start the engine with ZERO luck..
Went back onto the forums and someone suggested to use a inline primer bulb ( I go and installed between the fuel pick up and the fuel/water seperator ) to pump the fuel up and BINGO !!! She fires up like normal.
Engine runs for about 10 min and starts bogging again like what happened the first time at the lake..
I squeeze the primer bulb again til its hard and go start her up again..
BAM she starts again.. this time i keep the engine running till i hear it bogg a bit and i start squeezing the bulb and the engine stays running..
as long as i keep squeezing the bulb the engine stays running..
I'm thinking that i have a bad fuel pump?
Once i get the fuel flowing with the bulb she runs just fine.
Any and all comments appreciated
engine
Hull:
Regal 2100 LSR
Back story:
