I have a 77 MCM 888 Ford 302,
Ive drained out the old oil and about 2 quarts came out ?
I replaced a new sierra oil filter (primed) and started filling up the oil.
After some 2,5 quarts the dipstick read Full? After letting the engine run for some time I added some oil so the stick read full.
My clymer manual tells (and also others) that the oil cappacity on this engine is 6 quarts or 5.7 Liter.
I do not trust the level on the dipstick although it is the original one and also the tube (sidemount in oilpan) and the pan are original (rear sump).
I should fill 5 quarts and top off untill dipsticks says full and not overfill !
I am sure 3 quarts is not enough so put in 4 quarts and stick reads some 3/4" above full. And now I am confused, my MCM 140 4 cylinder takes 4 quarts.
Should I put in 6 quarts regardless what the stick says or burn the oil as 3 quarts can not be correct also for cooling.
I am aware that the sump differs the cappacity but this is an original standard 888. Does anyone knows exactly how much oil I have to put in this mercruiser engine.
Why can the stick be this much off?
Thanks in adv,
Frank
Thanks in adv,
Frank
