Stupid human trick #2:<br />Got the boat out on Monday for first run of the season (de-winterizing, etc..). Started first try, idled beautifully, waited for it to come up to temp, engaged drive for a slow ride for 3-4 minutes. Picked up my buddy who was parking the truck (total elapsed running time 8-10 minutes). Went for a short ride and noticed no speedo action. Shut everything off, leaned over the back of the boat and pushed the speedo pickup down, started wondering why the bilge pump was going like mad (and YES, the plug was screwed in!). Opened the engine cover but didn't see anything out of the ordinary...UNTIL I STARTED IT!!!<br /><br />Question: Which is faster - water entering boat through a 1"+ cooling exhaust(?) port on the block, or the 1/2" bilge port on the side of the boat?<br /><br />Answer: Not the bilge port.<br /><br />Real question:<br />It would appear that the gear clamp must not have been tight on the cooling exhaust(?) port on the front of the engine and blew the hose off the fitting. Engine wasn't too hot, so we put the hose back on, tightened the clamp, and headed for shore. Everything seemed ok, temp was good, no leaks, no strange sounds. So we headed back out and everything ran like a top. Is there any damage that might have been done without knowing it? Should I be checking anything at this point? Thanks in advance for your help.<br /><br />2002 Campion 545i, 2002 VP 4.3GL 190hp, Volvo SX single prop
