Measuring Fuel - Oil for outboard???
Bubba1235
No longer on Forums
Just picked up a bass/fishing boat with a Mariner O/B. This boat has a large fuel tank I'd guess at 25 - 30 gallons which is a little different to me because all the O/B's I've used I used with a 6 gallon fuel tank. So the tank currently has 10 or 15 gallons (guesstimate) in it. What's the best method to make certain my fuel - oil mixture is correct when I don't know how much gas the tank will take at the next fill up?
Fill with gas and figure out how much oil based on the gallons read form the pump and then add it? Will it get mixed properly like that???
saxrulez
Re: Measuring Fuel - Oil for outboard???
I carry my idiot bottle on the boat.
http://compare.ebay.com/like/160479099412?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
Werks good, lasts long time.
Don S
Put in 5 gallons of fuel. add oil for that 5 gallons. add 5 more gallons of fuel, and more oil.. Repeat as needed. Last fill may not take 5 gallons, so adjust how much oil you use.
Jlawsen
Don, your method is tried, true and correct.
Today's oils mix in almost immediately so it's o.k. to fill it with however much gas you want and then just mulitply that number of gallons by 2.6 to get the correct number of ounces of oil for a 50:1 mix. Ex. 10.251 X 2.6 = 26.6526 which you would just round up to 26.7 ounces, (it wont hurt to go to 27oz). You can add that in after the fuel because the first time you move the boat the gas will slosh and mix just fine. Actualy it's pretty well dilluted on it's own after just a couple of minutes.
Don S
I liked the hour meter for that. After a while you know if you did your normal boating for X number of hours, you will need Y number of gallons or in that vicinity. I was usually within a few gallons of how much I used.
If I estimated I used 12 gallons, I would put in oil for 9 or 10 and then fill it up and finish it off.
saxrulez
Somehow I posted this in the wrong thread/section a moment ago. Here goes again.
I honestly don't put the oil in before the gas and never have. Haven't had an issue yet. Mine is only a 12 gallon tank and I think I've only ran it empty once or twice. Those are the only times I'll put the oil in first.
I feel like if I still have 3-4 gallons of the correct ratio mix in, adding the other 8 gallons then adding the oil isn't going to be an issue by the time I get to the boat ramp. Starting and stopping the trailer, unhooking everything, backing down the ramp, I'm pretty sure it is well mixed by then.
Home Cookin'
to improve Don's perfect advice, let me suggest oil first then gas, so that if you guess wrong you will be rich rather than lean. But if you top off at a gas station chances are you get a burp by the time you get to the ramp to squeeze in that half pint that didn't fit.
I have been putting a pint in 6 gallons since I was 12 so I fill in 6 gallon increments, then a pint, and shift down to 3 gallons when I think I'm getting close. Also I use quart and pint bottles (I refill them) not ounces. Too much math.
I never worry about the oil and gas physically mixing.
Also I always put my additives in first, both so I know I have room, but also to get the gas to wash the stuff down the pipe. Add it last and it mainly coats the pipe, is my feeling. You can't have too much so it doesn't matter if you guess wrong on the last installment.
d.boat
This boat has a large fuel tank I'd guess at 25 - 30 gallons...So the tank currently has 10 or 15 gallons (guesstimate) in it. What's the best method to make certain my fuel - oil mixture is correct when I don't know how much gas the tank will take at the next fill up?
If the tank is any shape with a flat top and bottom, and you have direct access to the fill hole, you can easily make a dipstick for it and can also calculate capacity. Use a piece of unpainted wooden dowling or other stick of wood.
The easiest way to do the dipstick is to completely empty the tank - either by siphoning or by running it dry or nearly dry. If you don't have a spare tank with you when you run it dry, just bring a gas can(s) with an accurate three or six gallons of gas in them. After you run dry, you can add that three or six gallons and make the first mark on your dipstick before you re-start your engine. If you mark a 6 gallon level, just 1/2 it on the stick for 3 gallons.
Total capacity can be shown by filling full from empty or calculating volume in gallons (convert cubic inches to gallons)
When you get to the gas station, you can complete your dipstick. Fill it up to that first three (or six) gallon mark on the stick. Fill it in 3 gallon increments and note on the dipstick with a pencil where the fuel level is each time. Use a different increment if it makes sense. Then, after the stick is dry, permanently mark it with felt tip marker - it will last forever.
Then, when you later go to fill the tank, dip it first to determine how many gallons of gas you'll need.... approximately of course. Add oil for that much gas. Use a measuring device like recommended above if necessary, or just do it in rough 3 or 6 gallon increments and use pints or half pints of oil. Eyeballing/estimating 1/2 pint is close enough, if you are at all careful. It will even itself out over larger volumes and not be an issue at all. Add fuel on top of oil.
Of course you could use any increment you want, but that would involve measuring ounces of oil rather than "pints" or "half pints". I personally believe that using quart bottles of oil and simply eyeballing half pints and pints on it are accurate enough, and that erring a little on the rich or lean side is good enough if the top-off isn't exactly on a 3 gallon increment. Note I said "erring a little".
Hope it makes sense. I did that for years.
Chris1956
Bubba, All this is good advice. How much fuel do you typically use in a given trip? If it is 12 gal or less, simply buy two inexpensive 6 gal Jerry cans, dump a pint of oil in each and fill them up. Now siphon the fuel into your boat tank until it is full. Perfect mix every time.
Most Jerry cans are 5 gal, but if you look around, you should find some six gal cans.
