Re: Mechanic told me water is getting into the "motor"
From sounds of it, you would be reluctant to remove cylinder heads because you are a novice repairman. I think the plugs suggestion earlier was misinterpreted. What they were asking for is the condition of the plugs as far as color and buildup. The reason is, if the plugs have been exposed to water during combustion, they will appear steam cleaned and nearly spotless. If you pull the plugs...what do you see? Are they all the same (dark w/no sludge) or is perhaps one/two a lot cleaner than the others? Let us know. ALso, I would ask the mechanic WHY he knows water is in your engine? What does he see that tells him that? That info could help these guys answer your questions more specific and better. Good Luck
