dolluper
- Joined
- Jul 19, 2004
- 3,904
Hi Guys:There's a bunch of knowlegde on this site and I think it's time for some of us season pro's to turn over some of our tricks.Whether it's building an engine or taking out a broken bolt.Add your trick and see if someone else has a better way .We will all gain from this thread and have some fun.I will start with a simple trick
Subject : Crossfiring+ messy ignition wires
Take a nylon cable tie and wrap the wires with it loosely
Then take another cable tie,seperate two of wires and wrap this tie around the tie surrounding all the wires,pull this one tight and continue till you have seperated all your wires,works seperating 2,3 .4 .5 or 6 if you have a V12
Final step pull tight the first wrapper tie and cut of access ties off
Easy to seperate your ignition wires any location and very neat looking and fast
So what tip can you add ??????
