Mechanic's Manuals available for 1993 VolvoPenta 430B and SP CD-TRIM?
yooper49868
Just bought an as-is 1993 Glastron SSV-195.
[FONT=&quot]Engine Shield reads:
4101516637
104114011
[/FONT]
Engine is [FONT=&quot]430B / P5
4100 141230
[/FONT]
[FONT=&quot]868527
Outdrive is SP CD-Trim
[/FONT]
Hull and appearance are good. Changed crank oil and it looked like 2-cream coffee. Compression is good and consistent across all cylinders ( ~~ 160 psi). Separated exhaust and riser and found that gasket was cracked on one side. Saw coolant at the bottom of the manifold.
Specifically: looking for torque specs for replacing the riser bolts
Generally: Do you know where I can good shop manuals for this engine and outdrive
THANK YOU!
yooper49868
Fun Times
Hi, welcome to iboats!
You are looking for Volvo Penta part number 7732808 covers the Workshop manual AQ205, 430-434....http://volvopenta.store.elanders.com...rch=id:7732808
http://www.ebay.com/sch/i.html?_from...32808&_sacat=0
The riser bolts are torqued down to 18.5 Lbf. ft.
The exhaust manifolds are 26 Lbf. ft.
Or search online for,
http://boatinfo.no/lib/volvo/manuals...0_434.html#/18
Engine info:
View Individual Product:
Individual Products in Unit
Individual Information Serial Number 4100141230
DriveLine VPH1 811331
Status Commissioned
Manufacturing Date 12/22/1992
Shipped Date
Delivery Date 6/29/1993
Detailed Segment - as sold Marine Leisure Diesel
Control System
Control System Version
Rated Power
Rated Speed
Technical Data
Product Name
G4-B-AQ-3
Product Designation
430B
Part Number
868527
Production Period
1991-1992
Number Of Cylinders
6
Bore
101.60 mm
Stroke
88.40 mm
Compression Ratio
9.3:1
Displacement
4.30 liters
Fun Times has you taken care of
use factory gaskets
if you have coolant in the bottom of the manifold, may be from a winterizing event, as I do not believe that VP offered a full system FWC
