- Joined
- Mar 8, 2009
- 43,317
Don't want to hyjack another's thread but need to discuss code 44 with muc from your comment
Current motor in my Formula is a 500+ HP custom built motor. When it was being tuned in the boat with AFR meter and laptop it would throw a code 44 at times. Codes for MEFI 3 which I can find do show 44 as cannot detect knock activity.
If I always used 89 to 91 octane there was no code 44. When I disabled 44 (using MEFIBurn) I can run 93 and not have an issue or loss in power.
Volvo never used the “self spark sensor system test” that MerCruiser used. Also MerCruiser only used this for a very short time on the MEFI 1 ECM. By August 1994 they removed that feature. It was a code 43 that was set. MCM 94-12
alldodge If you were getting a code 44 on a MEFI 3 ------ 93 octane wasn't your problem.
This is why serial number can be so important. Not only is there a difference between Volvo and MerCruiser in what program is in the ECM. There is also a difference between MEFI 1-2-3-4-4a-4b
