ChrisCraftFan
- Joined
- Jun 18, 2013
- 184
Is anyone using the MEFIScan tool from ODB Diagnostics? It’s only about $200 and looks like it can record all parameters. Dose it work well? I will use it very rarely so for $200 that’s darn good, unless it doesn’t work. I just want to verify all the sensors are in spec and check for codes. I have a slight hesitation when ‘hitting’ the gas and want to chaise it down. Checking the sensor parameters will help eliminate them. The only thing i see it can’t do is set base timing. Anyone have thoughts?
