!! MEKP SCREWUP !!
alheim
I'm not generally this dumb, but today my friend and I were installing the last stringer in our restoration project (we haven't done any work on the boat since the summer), and while I mixed up some peanut butter, I completely screwed up the mix ratios:
Instead of using 1/100 MEKP/Resin, I used about 1/1000. I don't know what I was thinking, but instead of using one milliliter per hundred milliliters of resin, I was using one drop.
We didn't realize my mistake until we had peanut-buttered in the whole stringer .. literally sitting there for half an hour until we realized it wasn't hardening at all, and then realized what happened.
The last thing I want to do is to take out the stringer and redo it. My idea was to spray the peanut butter w/ MEKP (carefully, of course). I'm sure that will make it set just fine, at least on the outside, but will it work its way in to the deeper parts of the fillet?
Thanks for your help - and hurry! It's going to rain any minute!
-Alheim
p.s. - my friend is currently subduing his rage with a cigarette, haha
tashasdaddy
Re: !! MEKP SCREWUP !!
let us know what happens if you can. good question.
iwombat
I think you'll probably be better off mixing up another batch properly and putting a light coat over the whole thing. MEKP is a catalyst to trigger a reaction in the resin, it's not a hardener for a two-part system. Another layer of properly mixed resin will kick off the unmixed stuff underneath.
Plainsman
What does "kick off" mean?
Yacht Dr.
erm...
1. 1% MEKP to resin is not the correct ratio
2. How much mud are you mixing at a time ?
3. you CANNOT spray MEKP on top of your mud
sorry to say..you have to extract ALL and start over for proper crosslinking in your resin.
once again..how much are you mixing at a time ?
Boomyal
I know this is not helpful but I could not resist. I have a seething detestation for polyester resin!
I would also say that you have to clean the bulk of it out and start over.
iwombat
On second thought, the other fellas are correct - remove it. Especially since we're talking about stringers here. It just HAS to be right.
alheim
Yacht said:
erm...
Then what is the right ratio? According to http://www.uscomposites.com/pdf/MEKPDirections.pdf - it's one oz per gallon, which is actually a little less than 1%.
We're mixing at most about half a gallon at a time, with both of us working with it together.
I guess we might re-do it. Thanks for your advice - anyone else?
OhioLowell
Has is hardened out yet?
Just curious, I'm sorry I have no other advise as I'm pretty new to this stuff.
Lowell
Coors
it needs 4 drops per ounce, and will kick in 20 min at 70 degrees
Yacht Dr.
erm..It wasnt my fault..I was just trying to help..
your link is incorrect m8..
YD
plinko
1.5 percent mix ratio, 1 kg of resin you will need 15 cc mek cataylst.Anyone using polyester resin should invest in a set of scales and the proper squeeze bottle for their cataylst, they are only a few dollars and will give you the proper mix everytime. Some people think using more cataylst to speed up a job is good, but in fact is not. Too much will create heat, make a brittle lamanition, the same goes for too much resin.
flashback
Just went and looked a my gal of resin and it says to mix anywhere between 9 and 17 cc per quart depending on what the temp is in the work area...as for what you already did, like the yacht doc says, you will need to remove, it will not ever harden properly....
