Hey guys. After what seemed to be a successful rebuild, I took my OMC 115 crossflow out to the lake today. After about 15 minutes of fast idle and 3500 RPM, the boat loses power, warning horn comes on, I shut down immediately. We take it home, do some testing and pull the heads. Ends up #2 cylinder is scored badly and the side of the piston has rubbed aluminum all over the cylinder wall.<br /><br />Anyway, this is a cylinder that got resleeved over the winter. It also got a new Wiseco standard bore piston. There was still a crack in the block right outside the sleeve but the machinist said it was good to go. He was the one that actually encouraged the resleeve after I gave him the alternative to bore all 4 cyls of a different block. The cylinder scoring and melting happened in about a 1" wide path centered right on the crack in the block. I am fairly confident that the damage was caused by out of round cylinder or another flaw by the machinist. Does this sound reasonable?<br /><br />The machine shop is supposed to be the best in the area. I would expect them to take the blame and do some more machine work to fix the problem. However, as most of us know, the little bit of machine work required does not quite fix the issue of having to tear apart the whole engine, get new gaskets, pistons, etc.<br /><br />Also I'm not sure if I'd like to take my chances with this block again. I'd almost rather use the other block and get it bored and get all new oversize pistons. Of course the dealer isn't going to take back the 3 good standard bore pistons I just bought.<br /><br />So what should I expect from the machine shop? Are they going to buy me all new gaskets and pistons? Are they going to rebuild for me? Or are they going to tell me 'tough luck'? How should I approach this? What are they legally responsible for? Is any of this my fault? I live in Raleigh, NC.<br /><br />Thanks in advance for any help!
