Hi all. I need a little help. Late last year i replaced the impeller in my classic 50 and had a good telltale stream. To make a long story short,i was at the ramp and got in a hurry and fired up the motor out of the water. Took about 15 seconds to realize what i had done. I still had water coming out of the telltale at idle although not as strong. i think i took it out once more and no problems. I then pull it out last weekend ,put the muffs on and no stream. i dissasemble the water pump and the impeller is melted bad. After looking i determined that i overtightened the upper water pump housing and distorted it. Would this alone be enough to nuke the impeller? I did lube it originally upon assembly. Any thoughts ,experiences ,observations or butt chewings on this one?
