JTKelleyiii
- Joined
- Feb 19, 2012
- 49
Greetings!
I have noticed several posts lately about melted pistons so I thought I would share this and also ask some questions.
I was given a 1981 115 HP Johnson, J115TLCIH. Previous owner had no idea as to condition just wanted it gone. Has a nice Rapture prop on it though.
Right out of the gate I checked compression. Results as follows:
1 - 130 psig
2 - 10 psig
3 - 130 psig
4 - 120 psig
Pulled the heads and this is what I found:
The question I have is what would melt both pistons on one side? Based on what I have read on this site lately it seems that the biggest cause of this is an overheat condition. Water deflector on that side is not stopping flow. What else might cause an overheat on one side? Some kind of blockage in the thermostat assembly or water circuit elsewhere? Have pulled the thermostat off and see nothing grossly wrong.
Also, could some type of ignition issue with powerpack on one side cause this? This engine has a power pack on each side.
While the heads looked like they are scored there is very few areas you can actually feel. I also have discovered that all four cylinders on this motor have been bored out to .030 oversized already. What a bummer for somebody to put that kind of effort into the motor then fry two pistons.
Anyway, I am in the process of tearing it down. If crank and internals look good will bring to the machine shop and have it measured up and see if it is worth rebuilding (will require at minimum 2 new pistons, rings, etc.). If it is too much then I will save the prop and see if anybody wants the parts. Won't be out anything except the time tearing it down.
Any thoughts would be appreciated.
Thanks,
John
1 - 130 psig
2 - 10 psig
3 - 130 psig
4 - 120 psig
Thanks,
John
