MurphysLaw
- Joined
- Jul 28, 2007
- 29
After a fun day of replacing my shift spool, we had the prop sitting in a bin or water to try to put some load on it to see how it would shift. It turned out that I just splashed it all out which gave us a nice laugh to end the day. However I was not laughin about the steam I had coming out of the exhaust ports by the gimbal housing. I also melted the plastic tube from the water pump to the copper tube in the outdrive, so I know that its been getting HOT. My temp gauge isnt working but I believe that is fixed now. My dad, a former Merc mechanic, is thinkin that maybe I melted the fitting and/or gasket that the copper tube goes into, causing most of the water to fall out the prop because the pump was sucking the ear muffs closed to the outdrive. So that was just boiling the water inside the block. Or I may have an obstruction, which I plan to search for tomorrow. It did seem like there was a more than usual amount of water coming out of the prop. Does anyone have an experience like this? Or some input for me? I did run thru some weeds and found some in the pump, maybe they would have clogged something? Also, I pulled the temp sensor out today and a good amount of water came out, could that possibly cause some of the steam having a lack of water in the block? The water pump on the motor could be air-locked i guess
