Members Map in Restoration section
Jeep Man
I have referenced this map often. As I click on a marker it identifies that member in blue. Can the map be enhanced to go to that members profile at the same time?
jbcurt00
The map isnt directly connected to iboats, so i dont think so. BUT zeemaps has done some updates since i set that map up.
When i get home i'll see if its possible to link a profile, if its possible I'll check w the iboats admin team to confirm its ok w them to link back to a profile.
If its possible and ok w iboats it will probably still fall to each member to link to their own profile, it definitely wont be automatic when you add your pin.
