Reverse is not functioning correctly on my 1963 Merc 1000; feels like it is slipping. When I try to rev it up in reverse, I can hear a faint "ratcheting" sound. I can move backwards slowly if I stay at idle. When in reverse with the motor not running, I am able to force turn the prop by hand, past the clutch dogs. When I try turning the prop with the l/u in reverse, I can feel where it hits the clutch dogs (both directions), but with some effort, I am able to turn the prop further. I have ruled out the linkage as being a problem (the problem is there with the l/u off of the motor). When I had the l/u apart last year, there was slight wear to the clutch dogs (radius of less than 1/8", both fwd and rev).<br />Does anyone have any suggestions, i.e. shift cam and follower, shimming, acceptable wear to clutch dogs, etc.? Forward works great with no slippage. Clutch dog wear is about the same for forward and reverse gears.<br />Thanks.
