I installed a new tach about a week ago. After installation i launched the boat. Tach worked fine to about 4200RPM or so, and then would go down to zero. I did some research on possible causes, checked all connections(new) and everything checked out there. This morning i did the rectifier test from the Merc service manual. They have a flow chart of testing procedures. I followed it exactly:
You disconnect all connections from rectifier. connect positive lead of multi meter to ground and negative to "A" and "C", where the stator leads connect. I had no continuity. If you get that you reverse your meter leads and try the test again(black to grd and red to "a" and "c"). Again i had no continuity. According to the chart, this indicates a faulty rectifier.
I have almost exactly the same motor on my other boat. For grins i decided to test that rectifier. the tach in that boat works and I haven't noticed any funky charging issues. I performed the test and had the exact same results.
The meter is a good, working meter with a new battery. I'm positive that there is nothing wrong with the readings. I'm about to order 2 new rectifiers, for both engines, but thought it was worth a quick post to see if anyone with experience with these motors might see something else.
I did a stator test on both motors and they tested fine.
Ideas?
Ideas?
