Merc. 115 4-stk. Bad High Speed Performance
PHILLY9
Could Someone Tell Me Some Of The Basic Problems To Look For On My 2002 Merc. 115 4 Stroke. It Starts Good And Runs Good At Low And Moderate Speeds, But Will Not Go Over 3800 To 4000 Rpm. Some Of The Things I Have Already Done Are: New Plugs And Gas Filter,fresh Fuel,had The Throttle Adjusted And The Prop Checked. It Used To Go About 43 Mph And Now Will Only Reach About 30 Mph. Help!!!!
Dreddrs25
Re: Merc. 115 4-stk. Bad High Speed Performance
Sounds to me like a fuel issue. My Merc would start up and run smooth until about 12-15mph, then fell on its face. I found that my fuel lines had some kind of restriction. Messed with the pressure and got it running like a champ.
Check for blockage at the filter and be sure your fuel line has enough pressure. GL
PHILLY9
Thanx. I'm Going To Make Sure The Gas Vent Isn't Clogged And Then Try Using A Portable Fuel Tank. But I Have A Feeling That It Is Something Else. Philly
andy6374
Have you checked compression or verified that there is spark on all the cylinders?
PHILLY9
No I Have Not. I Don't Have The Tools To Check Comprssion And I Will Check Spark Later Today. Thanx
