Sylva-Ranger
- Joined
- Jan 17, 2016
- 164
Merc 115 4 strokes 2001 S\N 0T340811 (Yamaha engine)
Hi everyone, hi have problem whit this engine
The hi pressure fuel pump run randomly, at the begining can run ok for hours and sometimes stop or don't start after shot off......and now run about 10% of the time .
The fuel pump is new (OEM ) about 2 year ago
when engine don't start, no voltage go to the ful pump
wire/connections beetwin fuel pump and ECU are ok
if i put the fuel pump on a battery, the fuel pump work and engine start.
Seem to be the ECU ...ECU is not available from Mercury, and from Yamaha is 2300,00 $ Can
My question : It is possible too feed the pump directly from the ignition swich whit some relays or other means ?
Thank you
Thank you
