merc 115 pro xs beep codes
DBGRACING
I have a 22 merc 115 pro xs ...turn key on I get 1 beep ..as soon as start up I get 2 beeps ..nothing after that runs normal.every time I restart I get the beeps ..Any ideas would be great ..This a new motor maybe 10 hours .. Just want to know if ok to run ... Dealer is 3 weeks backed up...Thanks in advance
Don't know and wonder why the service manager couldn't answer the question or give you a hint
Check the voltage at the starter right after it starts to see if its low
DBGRACING
Thanks I'll try that..I was over at dealer today Service Manger said never heard of 2cbeeps right after start up ...and scanning ECU won't store anything if it doesn't beep when running and reduce power on gardian......Im not sure if any of that sounds right
Not sure that's right either. Would agree if there is a code it should be doing something else, like 2 beeps every so often just to advise there is a code. It won't reduce power unless there is something that could hurt the motor
QBhoy
Hi. Check your oil level. Also advise you to get the vessel view mobile device for it too.
