sarconastic
- Joined
- Jul 6, 2004
- 30
I have a '72 Merc 1150 that starts good, idles great but will not accelerate. It will rev the engine with the warm up lever some. But when you put it in gear, you have to run the throttle full forward and you get the boat moving just enough to create a wake. It's not even trying, doesn't bog, seems to run pretty smooth. I tried pumping on the primer bulb, thinking maybe fuel pump wasn't pumping, it kind of made the motor bog just a tiny bit. didn't hesitate or anything but it did slow it a little. I don't have a tac, but it would guess it's not getting over 1200 RPM's at the best.<br /><br />I haven't check the compression yet but will do so tommorrow. We just got back from a very dissapointing day at the lake. Hauled everything 60 miles there and no water sports today aside from swimming at the beach.<br /><br />I know the fuel is good, the tank was completely empty. Good oil mix. We ran it at that speed accross the lake to the local marina, got the Mechanic there to come out a take a peek at it, and without starting it immediatley starting talking dropped cylinders. While he's looking I inpect things little more, I was wondeing if the throttle linkage and everything was working. and it is. The butter flys are opening fully, the dist. is advancing. Both forward and reverse, all things seems to be mechanically moving. the choke flaps are open when not choked and working fine when activated. I checked the spark here at home prior to leaving while getting it started, it appears fine.<br /><br />I have read through the forum a lot and carbs seem to be the idea, but was wondering if it could be stuck reeds, just need to clean jets or am I am I going to get some experience rebuilding mercury carbeurators? Just one side note the boat was sitting 3 years prior to my aquiring it and spending the last two weeks getting it going again.<br /><br />Thanks<br />Sarc.
