stillstrokin10$$
- Joined
- Mar 30, 2010
- 11
I swapped out a bad mecruiser 120 for a good one. I had it running well while it was hanging from the cherry picker, but now it will only fire up while i hold the ignition down and as soon as i let go of the ignition the motor cuts out.
When i had the motor running good it also had its original wire harness.
I installed my old wire harness on it from the bad motor and may have put a wire in the wrong spot because the wires were not the same colors as the other harness. I am not sure how to trouble shoot this problem and any replies would be greatfully apreciated thanks
