sixstring531
- Joined
- Jun 6, 2007
- 62
My 97 Merc 125 Outboard has been making a quick "ticking in succession" (like a quick burst on a machine gun, but not nearly as loud) when running on the lake at 4000+ rpm. It is intermittent and when it happens, you can feel a slight loss of power while it happens. It only happens for about 1/2 a second then resumes running fine, then might do it again a minute later....sometimes didn't do it at all. It seems to do it more the faster you go or higher on plane you get.
The boat is now at the marina being looked at (which is not on the water) and they are trying to figure out a way to get it to make the sound under load because it won't do it in neutral.
Recently had a rebuilt lower unit put on (seems to be running fine), new control box and carbs (all 4 of em) cleaned.
Compression on all cylinders (from top to bottom) 110, 110, 111, 110
Any suggestions?
Thanks fellas
Any suggestions?
Thanks fellas
