t_money662
- Joined
- Aug 28, 2010
- 16
Hello All,
I bought a boat (my first) from a friend of mine, engine is a outboard Mercury 1400, S/N 6263573. I looked it up online using the links in the sticky thread above and it is 1980-81 I believe..First off, are there pdf manuals online somewhere for it? I found a few manuals on a link on this site for mercury, close but not my model.
Secondly, and most importantly, there are some issues with this boat-- It was serviced in the beginning of the year, plugs, oils , impeller was changed in this service. Turns out when my friend got it back, forward and reverse were switched. He ended up "living with it" for awhile, just pulling back on the throttle control for forward, and vice versa for reverse-- probably doing damage in the process, I'm assuming, because we took it out last weekend and the prop would not turn in the water. Out of the water it spun, however.
Long story short, he called his boat mechanic over to fix the forward/reverse problem, which we thought was the reason the prop wouldn't spin in the water. He ended up adjusting the shift shaft and switched the f/r back to normal, but the prop still could be stopped with your foot while in forward full throttle. Mechanic said it was probably needed a clutch, something about the clutch dogs worn out and slipping.
He recommended we change the clutch, and while we are at it we might as well change all the seals in the lower unit. He's a pretty knowledgeable guy, and he's doing the work basically for free (we are doing some paint work for him), only charging me for the parts which he said would be around $200.
Hopefully this will fix the problem, I was just wondering if the forward/reverse switch could cause the clutch to go like this?
Also, could this be the only problem, or are there other issues that could cause the prop to spin, but be able to be stopped with a foot?? PS we changed the shear hub in the prop before this problem (cracked), so it is not a spun hub. I'm just trying to narrow down our efforts.
Thanks in advance for any help/advice..love the site!
