Re: Merc 140 Low compression on 2 cyls UPDATE 08/12/04
I am confused as to what your concern about the valves is. Some "tapping" of lifters could be many things. if they quiet quicky at idle, I <br />wouldn't worry. Thin oil, leak down of a lifter<br />over a few days does happen. if they pump up<br />thats the main thing. I thought your orig prob<br />was low compression, readin your testing showed<br />a ring problem. Could be stuck, worn,or broken, any of these are far worse than a intermitent tap.<br />If some "Marvel Mystery Oil" doesn't free the rings,(I love that stuff)then pull head check for<br />scoring, excessive wear at the top of the cylinder where the rings expand, or general condition of cylinder.<br />Be advised that a new head gasket at least will be required if you pull the head, torque wrench<br />intake exhaust gaskets, sealer, ect.<br />The head pulling will only allow inspection, so be prepared to have to pull motor and rebuild<br />if you find scoring excessive wear ect.<br />I don't know what prompted your compression check but, not much can be done short of soaking rings<br />in the cylinder with head on. if they don't free up then a ring job is in order.Running it untill she dies then rebuilding in an option, some good mechanics have "scopes" that can check the cylinder without pulling the head. I feel after reading the tests you have done it is a ring problem. Hopefully the rings are just stuck and some soaking and running motor with some cleaner products will free them up. A boken one would require a repair, check part avail, possible rebore with o-size new piston. It is a subjective call, worst case--- broken ring tears up cylinder<br />mandating a rebore and o-sized piston, if avail?<br />Then have to decide if doing whole motor is best course. rings, pistons? main and journal bearings<br />cam, chain, valve job,ect ect ect.<br />I vote for MMO and stuff like Sea Foam, run on the "hose" with constant re compression testing to see if it improves.<br />Then decide what the motor is worth to you.<br />Only you know the hours on the motor and the possiblity of needing a rebuild.<br />It is a tough call, many have gone through it,,<br />I know I have and will again.<br />Good luck
