Re: Merc 140 low RPMs
My 19.6" Doral has 140 hp. top speed attained 29mph.<br />The boat has been tuned up last week. It has a new Prop. We changed spark plugs, points, ignition coil, new starter, new battery cables, changed gear and engine oil, new cap and rotor, and condenser. Relocated fuse panel, all fuses checked are a ok. Checked carborator its tight.<br /><br />I still have max rpm at 2900. It idles at 650 to 700 rpm on Start up and Water temperature is at 140. oil psi is good. Cuts out when increasing spead from idle to quarter speed. Its Ok when spead is increased slowly but has a ping at half throttle. Then ping disappears at three quarters to w.o.t. <br /><br />Things to be done is change feul filters. <br />Could it be the accelerator pump causing it to bog and loose RPM? Or Would a dirty fuel filter cause it to loose rpms?
