Boatin Bob
- Joined
- Sep 24, 2001
- 1,858
Hi Guys....I've got a 1976 Merc 150 hp inline 6. Didn't seem to have the same power as last year for pulling a skier so we pulled each plug wire off one at a time to see if all 6 were firing. # 3 was dead, swapped plugs with # 4, no change, grounded plug with wire on and lots of spark from plug, so we did a comp test, all 6 cyls in the range of 115 to 125. The plug was bone dry and yet # 4 (same carb) works fine. The manual shows a reed block that goes around the crank so I pulled the carb off and could see a few of the reeds for # 3 and # 4. As there are several reeds shouldn't I still be getting some fuel, what else can stop fuel from getting to the cylinder? Also if it is reeds does this mean the engine has to be dismantled? Thanks in advance for any ideas, suggestions.
